Screamer27
Registered Member
Hey guys, this is my first post, I've been a long time lurker.
I have a 91 K5 that I bought with a blown up rear 10bolt. I bought a 14bolt SF, and converted the front hubs over to 8 lugs. New 33in BFG all terrain's. I was a GM technician for 5 years, and i have no idea, my GM buddy's are just about out of ideas. I'm about to the point of either craigslisting it, or pulling the plates and leaving it on a level b
In 2wd with the hubs unlocked, it is twitchy, the steering is tight, NO slack in it at all. I like the "tight" feeling. Now, you can lock in the front hubs, and leave it in 2hi, and it handles just like normal. Leave the hubs locked in, and put it into 4hi. This truck WILL not stay on the road at anything over 30mph. you can start to feel the wander at about 15, but at 25 it is all OVER the place. (i've seen some bad things in my time... This is BAD!) You kick it back into 2hi and its fine again, I can run straight up to 80mph in 2hi and it handles fine, just when its in 4hi it is completely non-driveable. I have rebuild just about everything on this truck.
Here is a list of things I have replaced;
power steering gear
power steering lines
power steering pump
power steering gear mounting to frame (welded in new frame, and reinforced)
new rag joint
rebuilt the steering column
new drag link and tie rods from knukle to steering gear
new centerlink from hub to hub along with the ends.
new upper and lower ball-joints
new heavy duty u-joints in the front axle
new rear drive shaft u-joints
new brake rotors
new brake calipers
new brake hoses
new brake lines
new brake drums
new brake pads / shoes
new rear wheel cylinders
new springs front and rear. (4 pack up front 5 pack in the back, plow truck)
6 new Bilsteen shocks
new steering stabalizer
i have way to much money into this rusted peice of junk, I have probably about 3-4 grand into the suspension, axles, and brakes. The truck honestly ain't worth more than 500 bucks due to the body rusting off the frame(right behind the driver and passenger is completly gone, no more seat belt mounts, tail gate supports completly gone and so on.
I just don't understand what would cause it to not wander at all in 2wd, but it will take you in the ditch over 30mph, it is unbearable at 25mph. I've gone through just about everything, The pinion angle is perfect, the only thing I can think of yet is either the newer warn hubs are locking and unlocking while under a load. Or it may be a u-joint in the front drive shaft. Everything else is new, it was just on an alignment rack about 2 weeks ago. I'm at my wits end. any help is appreacated. The snow is about to fly and the truck is stuck in the driveway.
power steering gear
power steering pump
new rag joint
new brake rotors
new brake calipers
new brake hoses
new brake lines
new brake drums
It is kinda funny watching the rear shaft and rear pinion spinning in the pumpkin, but the tires don't move. so i put it in 4wd and drove it home, I didn't really notice it at that time, but, at that time the whole front end was loose, the steering column was basically laying in your lap and it was all over the road then too.
