so i inherited a 94 jimmy with a spun crank main/rod bearing. i am now almost done with rebuilding it after all the machining/boring/decking/prep and just need to put the heads/manifolds on. any idea for the best priced spider injectors for it? most ive seen are over 200$ or can i just clean my current one out and be fine. also if anyone has some good pics of their 4.3 from the front accessories and the wire routing that would help alot. thanks
