97 Tahoe 2 Door
Discussion in '1992-Present Chevy & GMC models' started by skunked, Feb 19, 2015.
  1. wetoolowdingbangow
    wetoolowdingbangow 1/2 ton status Premium Member
    Nov 30, 2014
    4,632
    3,037
    East Bay, Ca
    Build(s):
    Interesting rockers.
    Whatever they can do to save .0015$
    Put the big block in there lol!
  2. skunked
    skunked Orange Block Because Chevy Premium Member GMOTM Winner
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Still sweating it out in the garage. Upper manifold was a tight fit, needed some extra lube. Valve lash is set, now onto the covers, plugs, accessories and maze of sensors.
    wetoolowdingbangow likes this.
  3. Bent77
    Bent77 Black is the new Orange Premium Member GMOTM Winner
    Dec 3, 2002
    18,390
    19,918
    colorado
    Build(s):
    Yay team. Hurry up so we can get a FI tech review on the super big gulp
    skunked likes this.
  4. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    I made it to 12:15 and hit a wall at about 95% complete. Tomorrow (or I guess later today) I'll finish it up.
    Smokinthehippies and Bent77 like this.
  5. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    It's all back together but it's running like shit (rough miss) and throwing a PO135 light. Im thinking I have the distributor off a tooth.
  6. wetoolowdingbangow
    Nov 30, 2014
    4,632
    3,037
    East Bay, Ca
    Build(s):
    Heater circuit malfunction on bank 1 sensor 1?
  7. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Sorry, P1345
  8. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    It's sensing a camshaft to crank shaft correlation issue. I knew I should have pulled the cap and marked the rotor orientation.
  9. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    The google has told me that the distributor has an "8" or a "6" on the distributor housing, I should have pointed the rotor at the 8 since this is a V8. I'm pretty sure I'm waaaaaay off that mark, I pointed the rotor at #1 :screwy:
    found this picture on the interwebs to show you all
    so tonight I'll put it at TDC, pop off the distributor cap and see where I had it set.
    I can smell the rubber already :burnout:
    oh and it's a 102 outside right now, should be 104sh by the time I'm out there :flipoff7:
  10. Bent77
    Dec 3, 2002
    18,390
    19,918
    colorado
    Build(s):
    Hey at least you're gaining
    skunked likes this.
  11. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Runs so much better now :burnout::saweet:
    I hear a little noise on the passenger side head. Think I need to go through and double check the rockers adjustments once more. Other than that, it's running pretty damn good
    Rugby_7 and Bent77 like this.
  12. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    11,887
    9,416
    Toe-peek-ugh, KS
    Build(s):
    3
    Quick post got me. Nice work dude.
    skunked likes this.
  13. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Feels good to get this one off my plate.
    Bent77 and GWeakland620 like this.
  14. Bent77
    Dec 3, 2002
    18,390
    19,918
    colorado
    Build(s):
    White truck time FTW...
    skunked likes this.
  15. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    FTMFW!
    Bent77 likes this.
  16. Bent77
    Dec 3, 2002
    18,390
    19,918
    colorado
    Build(s):
    Glad you got this. Hopefully the tick is something minor
  17. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Sounds like loose rocker. I should be able to fire it up with that cover off and know pretty quick.
    Bent77 likes this.
  18. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Finally had a chance to pull the valve covers and adjust the rockers with the engine running. Also picked up a set of new AC Delco wires, runs good and no check engine lights. Need to pickup a magnaflow muffler, the OE muffler has a hole in it and sounds like crap.
  19. Kay86K5
    Kay86K5 1/2 ton status Premium Member GMOTM Winner
    Mar 9, 2012
    2,827
    2,054
    Emmett, ID
    Build(s):
    Updates? Looking good BTW!
  20. skunked
    Feb 27, 2013
    12,570
    12,243
    Placer County CA
    Build(s):
    Thanks.
    I've been daily driving it for the last few weeks and I keep getting the P1345 when I start the engine. I can clear the code while driving and it will usually stay off until I restart the engine again. After reading about the issues surrounding this particular code I've decided it could just be a worn out distributor so I bought a new distributor from rockauto which I received yesterday. Hopefully that clears it up.
