2toneZ
I think doing a crossover like this would eliminate a "dead spot in the steering compared to doing this with a tie rod end.
Comments? Ideas
Comments? Ideas
What did you use for drag link and tie rod ends to do the steering setup like you did? I have always wanted to try and go that route to get away from buying a new pass side knuckle or the associated parts for regular crossover steering.
I should have done that on mine. Would have made the trac bar location way easier.
