'99 454 w/ 700R4 - tv cable solution
Art'74
OKC
I have a '99 454 out of a suburban in my rig. I also have a built 700R4 behind it. Since the 454 had an 4L80E (electronic kick down control) and the throttle pushes toward the transmission instead of pulls away from it, what have you guys done to hook up a TV cable from the transmission to the Throttle?:confused:
I am sure there are fancy (read that expensive) solutions but you guys are always great with common (read that cheap) solutions.
Let me know.
Try to find a van cable that is longer, and then fab your own bracket that bolts to the intake or the stock throttle bracket.
