looks sweet! i want
looks sweet! i want
..not much you couldn't climb with that setup!..
You are
Good thing for overtime...
The crawl ratio with my 4.56's will be 100.78:1, and just as important to me is the final drive ratio is .73:1. Finally getting an overdrive behind my 6.2 will be a godsend. It should be a lot quieter on the freeway and get much better mileage. For wheeling, yes it should be able to snap axles at will...
which just means 35 spline outers and some alloy shafts will undoubtably be in my near future.
FWP said:You're so money $$$
Emmettology 101 said:Thats what I figured. They look good!!!! Cant wait to see it under tRusty.
And what's wrong with Smurf blue?tRustyK5 said:Cases are painted, Rustoleum hammered silver. The NV4500 needs another coat to finish covering up the smurf blue that was on it.
Rene
(see sig)
That there is some serious shiznit.tRustyK5 said:You and me both...hopefully I can sneak some time off in september to get it swapped in. It sucked to have to give up my vacation time at the end of this month.
Rene
dremu said:And what's wrong with Smurf blue?(see sig)
And obtw Rene,That there is some serious shiznit.
-- A
Emmettology 101 said:Hoepfully they'll make up the vaca time to you.![]()
tRustyK5 said:They'll have no choice...I actually could have been a dink about it and took the time off anyways, but I felt it'd be more to my advantage to play nice right now. I may be able to parlay the two weeks i just gave up into three weeks later...![]()
Rene
Plus it would give you plenty of time to get all your new parts installed! tRusty wont know what to do with all the new stuff on!
.yellowK20 said:got any good swap info??? concerning the 4500 to engine mine already has a t-case
