Starting to plan out where to spend the holiday bonus that I haven't yet received. Based on feedback from you guys, the cam I currently have is too small. Mind you I haven't turned the thing over yet.
Here's a recap of the engine specs:
Block: GM 2 bolt BBC 454 .030 over Mark IV
Rotating assembly: GM cast crank, Speedpro flat top pistons (3cc eyebrows), retrofit hydraulic roller lifters
Heads: Edelbrock Performer High Compression aluminum cylinder heads...oval port, 100cc semi-open combustion chamber. Should be at about 10:1 compression
Intake: Edelbrock RPM air gap dual plane
Exhaust: Long tube headers with 2" primaries and 3.5" collectors (have these). Will run into dual 3" exhaust (need this)
EFI: Going to run FAST EZ EFI for sure, possibly the new 2.0
I've spoken with tech support guys at Comp and Lunati and have been given the following cam recommendations:
Comp: 11-422-8 -- advertised duration 270 In/276 Ex, lift 510 In/510 Ex, lobe sep 110*
Lunati: 20110711 -- advertised duration 272 In/280 Ex, lift 575 In/575 Ex, lobe sep 112*
Thoughts? burnout
Thoughts? burnout
