It looks like CK5 has a "mainstream" design for preventing spring wrap. That is, a two-tube bar from one axle tube, tying to a cross-member with a shackle. Here is an example from Frizzlefry:
I'm making plans to build one, but I have a question about ride height. As you load the back of the vehicle, the traction bar will force the pinion angle to change. Is this good or bad? Can a practical build make the geometry work in your favor and keep the angle out of the pinion U-joint as the suspension cycles?
Or should you make the shackle longer with 2 or 3 sets of holes so the height of the bar can be adjusted? You could add a second height for towing or taking the top off, etc.
