Allison 1000 4wd to 2wd ?
sweetk30
Back to play nice .
in the back of your brain
So anyone know parts wise what i will need ?
Its the 1st gen 5 speed unit in a 2500/3500 truck with a 8.1 .
What are you doing with it? I do know from experience that the 4wd needs that last vss to function and with the vss mod in the tcase the trans will only shift in 1:1 otherwise the gear reduction will make it think it’s slipping and go into limp mode.
I haven’t however tried using the 263 tcase that comes behind the Allison mainly bc it’s driver side drop.
So you’ll need a housing for that vss that’s the same speed as the other sensors in the transmission
