45% is almost halfway around,that should be sufficient--most OEM v belt setups are lucky to have that much belt "wrap"...
I've had several different alternator belts on my 6.2 Suburban and all but one screech like hell after a cold start,until the fast idle solenoid shuts off...
Gates belt was worst,I tried a Dayco "cogged" belt and it was quieter,but still screeched for a short time after a cold start..
Dayco listed a 15/52"thick belt (15480) as "stock" and a 17/32" one as "heavy duty"(17480) and the thicker one was much quieter,but also did not sit flush in the alternator pulley,and eventually it wore the sides off and the top cover flew off it..
The 6.2's v belt setup never was stellar to start with,really..
But any belt will squeal if the alternator is trying to max out,new old,so I'd still look for excessive draw first..
