uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
do not use aluminum shims.way too soft.i already had this happen with mine.i almost lost my axle out from under my truck.so i went with steel zero rates with 4 degree cut.it hasnt had a problem since.plus you get a one inch lift with it for cheap.i think i payed 50 for it.Be prepared to unbolt your spring pack and remove the broken wedges on a trail if you wheel with those. Ive been through around 4 sets and they always break and loosen the spring pack. Go with steel, or for the price, cut and turn your spring perches 4%.
i got mine from az kicken 4 wheel drive.i think hes not makin anything anymore.off roAd design on this site makes them i do believe.Where'd the steel ones come from? I'm gonna' chk the links...
I was going to get mine from JKW, but Teraflex sells them too and they are local to me.They also sell longer center pins.
