Enjoy....
That was a major PITA, but the durn c-clips were rust-welded to the u-joint caps. I could break pieces of them off, but couldn't get enough off to get them out. If you look close you can see them still stuck to the caps.
I didn't want to micky-mouse around and damage anything so I busted out the grinder. Cutting through u-joints 8 times is a major bummer, the first half is OK, but then once you get nice and deep the disc just wants to bind all the time. Anywho it is done.
