thedrip
Everything is in Gainesville FL. We can work something out for shipping on everything (you pay) but the axles (you pick up). The time has come when my truck is just not entertaining me anymore. I'll get back to offroading in a couple years. Right now its time for something fast and small. Everything is currently installed, hoping to have most (or all) of it in the back yard by the end of this weekend.
Axles (Chevy 1 ton) $1500
D60 Front, 4.56 Limited Slip, cross over arm, hydro assist cylinder
14bolt rear, 4.56 detroit, disc brakes
Front axle includes DOM tie-rod and drag link
Steering box for fullsize chevy 73-87 $100
Tapped top cap, aftermarket end cap for hydro assist
2wd with Wagoneer pitman arm, machined for Chevy drag link end
Grant Steering wheel $25
Challenger style http://www.grantproducts.com/products/view/15/
Includes adapter to GM truck steering column
Well used, paint has flaked, metal has rusted, rubber isn't perfect
16" Aluminum 8 lug wheels with 35" tires $150
From 1997 Ford F350 srw truck
Tires hold air, thats the best I can say about them
Hydraulic clutch pedal set for 84-87 fullsize $100
For truck with hydro brakes
Includes master cylinder that works
Missing one support strut from pedal pivot to master cylinder
Front Driveshaft $50
Square tube, 1/4" wall
1350 lower joint, 1350/S44 combo upper joint with flange to GM CV flange
Painless Harness knockoff. $150
Currently installed in truck. Minimum of hacking on the wiring. 14 circuit fuse block. Wired for no name brand gauge set (will include gauges and senders).
email to [email protected] will get a quicker reply!
