Atlas T-Case K5 Blazer
rdohara
Apple Valley
Just got mt Atlas in my 84 K5 wanted to see if anyone has put a Atlas T-Case in there K5 and what you did for the twin stick. Did you cut the floor, make new shifters etc...? What did you do to get the twin stick up out of the floor to work?
I have not installed mine yet, but when i do i'll be enlarging the stock hole and installing the NWF cable shifters in the stock-ish location.
Good to see other guys getting their Atlas t-cases... Got mine but waiting on my HAD flanges and e-brake to show up before I install.
I am planning on just enlarging the hole if needed and tacking some sheet back on there if it has more opening than I need. I will be running the Atlas twin sticks for now. I would like the cable shifters but that is an upgrade for later :D
When I twin-sticked my 205, all I did was enlarge the hole for the 241 shifter, and used sheet metal to cover the unused portion. Just get a big piece from the local hardware store and cut it to fit with a few inches overlap on all sides so you can seal it up good.
