ATV and K10 Feeler
thebluemax
Hutto,TX
this is just a feeler but I need to sell :
2008 Honda Rancher 420 ES. Snorkel kit,factory rims/tires, Aluminum Products stick guards, reverse mod, 40 mm ammo can bolted to rear rack....and for the bad....needs a piston/rings for sure(burned oil) and battery I think. $open to offers
1984 k10 SWB, 350,700R4,NP208, 33x12.50 mudkings on 15x10 mismatched rims,10 bolt front,14 bolt rear, echobit shackle flip, ez inch rear, DIY4X rear shackels,procomp front springs,heavy duty front bumper, ORD swaybar disconects,extended brakelines, 4.11 gears, poly motor mounts,poly transmission mounts,poly spring bushings,poly swaybar bushings, drop drag link,drop pitman arm,warn hubs,headers,dual 2 1/4 flowmasters. The bad: needs brakes bled,rear springs perches finished, windshield and weatherstrip, exhaust hooked up,inspection and registration. $2000 or may part out?
Make an offer and the worse I can say is No
located in Hutto, TX
A little of both, I totaled the tahoe and ended up buying a newer truck. The wife says I dont need two trucks. I put it up for sale to keep the peace.
