auto to manual gauge cluster question
jovibuilt
Registered Member
spruce pine nc 28777
I have a 1989 sububran with 700R4 that I am going to swap for a SM465.My question is what to do where the cluster has the PRND21.I would like for it to look factory so no tape over it.Do the manual truck have a piece that goes over the hole?Where could I find one lmc?Thanks
You can easily just remove the indicator plate and all that you will see is the black plastic gauge cluster cover. I can take a pic for you if needed as i'm in the middle of an Autometer gauge swap and I have my cluster apart on the work bench.
