axle caster angles between axles and pad height
K85 Octane
People Fatigued
San Bernardino CA
Hmmm lets see. Looking to swap my D60 in place of my D44. Not today and prolly not any time soon, but the question is in my head.
I need to cut down my zero rates so I can have the proper caster. The shims I have are not enough and I already have crossover draglink to leaf spring clearance issues.....so going with a thicker shim is out of the question.
Here are my questions.
*When I swap axles, will the caster be way off again? Or does caster numbers usually stay close between axle swaps?
*Does the steering arm of a D60 sit higher above the leaf springs or lower than it's counterpart the D44?
Thanks :bow:
Your caster angle should remain very much the same it is now.
I think the D60 arm will be higher.
