Hey guys! Been a while since I've been active on here, but I have a question that I know you guys could answer. I've been getting mixed opinions from everyone I ask and it's driving me crazy!
WHICH IS BETTER: 14bsf or a 10 bolt?
I understand the 14bff is the ideal axle for a wheeler, but in my specific application, I believe its unnecessary. I also like my 6 lug 15x10 slot mags.
My truck really goes against the grain of 95% of 4x4 K5 builds. It's a "hot rod" 4wd truck I primarily use as a cruiser. I always jokingly call it an all wheel drive gasser. It's good at nothing, but its a ton of fun! It has a 500hp sbc, performabuilt 700r4, billet 3200 stall converter. Torque and weight is the leading cause of failure for an axle, but this truck is relatively light, and my 33" tires should hopefully be the weak link.
I understand the 14bsf is a much beefier axle, but it does seem like they get a lot of hate. I know a guy who broke his twice with a pooch of a 350 while street driving. He doesn't have the greatest track record with mechanical things though, so take that as you will. & With that being said, I also know a guy with a turbocharged 10 second short bed K10 that ran the 10 bolt for an amazingly long time. It did eventually break and has a 9 inch now, but its also in the mid 9's while making 1100hp.
So.... Im up in the air! What would you guys recommend? Build the 10 bolt or the 14 bolt? How much more hp does the 14 bolt take to turn compared to the 10 bolt?
Thanks in advance!!!
& Also, on post #6 I believe I found the "spacers" you are referring to
