Fry
Wondering if installing a Detroit causes more axle wrap?
I swapped out my 14bsf for a ff with a detroit and I seem to have more axle wrap than before, only when it starts spinning or nears finishing spinning, once spinning at a higher speed it stops. I also got rid of a 2" block that was in the rear at the same time. This is on stock leafs (3/4 ton HIGH GVW) & new shocks.
Also noticed on the highway when I let off and gun it, it seems to jump to one side or the other a bit, wondering if that has anything to do axle wrap or the detroit. Thinking the alignment is off and my caster will be increased with it being 2" lower on the rear, making the handling a little funny.
Any thoughts?
Any thoughts?
