B52 brackets with stock front springs?
usaf_blazer
Registered Member
Mesa, AZ
so I have been some freshening up on my trucks suspension since I recently returned from my deployment. when I was installing my fresh 4" lift, I noticed that my front suspension main spring hangar brackets holes were extremely wollared out. so my question is, can I install the b52 brackets and still run my recently purchased 47" springs and still have the proper geometry?
Yes, you may need different bushings on the front spring eyes though.
This is correct. When I installed my A-bomb bumper (with the b-52's brackets integrated) I still had my normal 4" lift springs on. I kept the 4" lift bushings in the front springs but had to cut them down a little bit to fit...or you can just order some new bushing from DIY4x and the same time...you will run the springs in the most rearward hole on the b-52 brackets
