In that case, I standby my previous webnosis. A shackle flip will angle the pinion upward. This is usually ideal for a CV driveshaft. However 6" blocks (and a 1") will make it worse - plus the taper if it has it. Add to that the axlewrap that 7" of block will give you and it's understandable that you'd have a vibration.
Now for more questions...
1) with 52", 6" lift springs in front and a shackle flip and 6" blocks out back, I'm guessing you're running around a 10" lift. Is this accurate?
2) It seems odd that a truck with 52" front springs would be running blocks in the back - i know - not a question, just an observation.
3) CV or stock driveshaft?
I'm not flaming your truck, but at 10" of lift, you've exceeded the "I'll just bolt this on and the driveshaft should be OK" threshold. I recommend you make the adjustments to make it sit how you want (hopefully this plan doesn't include 6" blocks), and set the appropriate pinion angle for a CV driveshaft (2 degrees down from the drive angle). You'd be surprised at the driveability improvement, I think.
