josh86k10
So last night on my way home my voltage regulator in my alternator apparently went out because as I was driving I noticed "Wow, my windshield wipers and power windows are fast tonight!" Taking a second to realize what was going on, I checked the gauge and sure enough 18+ volts (gauge burried to the right)
. I parked it as quickly as I could (I was less than a mile from home) and shut it off. So replacing an alternator... no big deal.
Now the potentially bigger issues:
Since I shut it off, the key no longer does anything, no turning over, no clicks, no radio or blinkers in the on or acc position, nothing
. Lights and things that are not tied to the ignition switch still appear to be okay (except for a blown bulb or two). The ignition fuse is not blown
. Did the 18+ volts fry my ignition switch? If so is it easy to replace? What else did it likely damage? Thoughts?
It sure sucks having an immobile truck sitting in the driveway in everybody's way. Help
. I parked it as quickly as I could (I was less than a mile from home) and shut it off. So replacing an alternator... no big deal.Now the potentially bigger issues:
. Did the 18+ volts fry my ignition switch? If so is it easy to replace? What else did it likely damage? Thoughts? It sure sucks having an immobile truck sitting in the driveway in everybody's way. Help
