All depends on the clamshell of the motor mount. 2 and 4wd use different heights of clamshells.
I had a K30 once with the tall fuel pump and it sat on the crossmember. The vibrations were enough to wear a hole in the pump where it rubbed against the crossmember and leaked fuel everywhere. A short pump fixed that problem.
I think that motor was swapped in and used 2wd clamshells as the harmonic balancer was real close to the crossmember, too.
If you use a true 4x4 clamshell, I don't see why a tall pump wouldn't work. On my '85 K30, everything is a true 4x4 part on it but as long as I've owned it, I've never paid attention to which pump it has.
