I've got a 4" Pro-Comp (I think) lift on the 89' but I get a lot of popping and clicking sounds up front everytime I turn the wheel. After some investigation, it appears that it's coming from the spring pack. Additionally, the front end seems to be springy when I hit bumps.
I am considering just swapping out the old front springs for some BDS Softride springs but don't know if there will be any vast improvement or not. I've also heard about Tuff Country Softride springs being good as well.
I've considered going down to a 2.5" lift eventually so my thought is get a 2.5" front springs and then add a 1" zero rate to get an overall lift of 3.5". The front may sit a little lower than the back but if needed, I could play around with a smaller block to get it level.
The BDS's have plastic end protectors on each leaf so I'm thinking they are going to be much quieter than the existing ones.
I don't know the age of the Pro-Comps either so it would be nice to get a fresh set in there.
Front Springs would be $284......
Does this sound like a solid idea or just waisting money??
Just don't like the constant popping sound up front every time I turn.
