Beag's 67 Chevelle. Autocross cone crusher.
Discussion in 'Other Rides' started by beags86, Sep 23, 2018.
  1. acm
    acm 1/2 ton status Premium Member
    Sep 4, 2013
    1,273
    4,097
    TX
    You aint got the 'merch!!!
    & where's that unlike button???
    tRustyK5 and beags86 like this.
  2. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    13,451
    17,573
    In my shop
    Build(s):
    3
    I still can't manage my ADD worth a crap. But between doing miscellaneous stuff I finally bent my last brake line.
    Decided to do a quick write up on the AN stainless line. If anyone cares how I did it.
    Cut the line.
    And deburr it. Get yourself a 37 degree counter sink.
    Deburr.
    You need to slip on your tube nut and ferrule.
    And get yourself a good quality 37 degree flaring tool.
    After I looked around everyone says the ridged was the way to go. It has a automatic brake way so you can't overtighten.
    You want to recess the tube slightly. I learned through trial and error.
    I like to use lots of water displacement on the 40th try when I am tightening the flare tool down.
    Once your done the fitting will look like this.
    Then you can bend your lines cut to fit and flare the other end.
    And your set.
    Last line on. (Middle line)
    Tomorrow night I have to take all my lines off and clean them with brake clean. Then I'll tighten everything down and start bleeding.
  3. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    4,989
    5,482
    Cleveland, UT
    Build(s):
    4
    I was wondering how you did lines like that.
    beags86 likes this.
  4. beags86
    Jan 18, 2011
    13,451
    17,573
    In my shop
    Build(s):
    3
    I found the line is less likely to crack the deeper I let the countersink dig.
    Oil helps alot.
    I like the tube nut as it seems like they are less likely to strip with an open end.
    Put the ferrule on the right way dummy!
    ( no pictures of that)
    You have to have stainless tube to use this.
    Think that's it.....
    TerryD and Truckman4life like this.
  5. beags86
    Jan 18, 2011
    13,451
    17,573
    In my shop
    Build(s):
    3
    Burning the midnight oil.
  6. beags86
    Jan 18, 2011
    13,451
    17,573
    In my shop
    Build(s):
    3
  7. shady
    shady 1 ton status Premium Member
    Jul 31, 2010
    10,843
    6,663
    iowa
    Build(s):
    6
    I know the feeling
    TerryD and beags86 like this.
  8. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    21,801
    5,655
    Lincoln, CA
    Build(s):
    5
    TerryD, shady and beags86 like this.
  9. shady
    Jul 31, 2010
    10,843
    6,663
    iowa
    Build(s):
    6
    Seems like a growing trend ... 3 steps forward, 4 steps back :doah:
    TerryD likes this.
  10. fastazz81
    fastazz81 1/2 ton status Premium Member GMOTM Winner
    Dec 21, 2007
    1,602
    2,648
    spanaway wa
    Build(s):
    Wear a helmet
    Justin V, TerryD and beags86 like this.
  11. TerryD
    TerryD Mildly demented... Premium Member
    Jul 27, 2008
    4,524
    1,499
    Covington, Va
    Build(s):
    I find those days tend to go better when I abandon the project and take the kids for ice cream and french fries.... in another town...
    shady and tRustyK5 like this.
