Tx Surveyor
Registered Member
Hey Everyone,
I'm working on buttoning up my engine swap and I was tightening down my bellhousing to motor bolts.
They were tight going in, and they were tight coming out.
When I was putting them in I went through my 4 wheel drive shifter hole. After they were in I looked at the top of the motor and noticed the bolt holes "humps" were cracked at the top.
Is this going to be a problem? If so, how can I fix it without having to pull the motor? What would cause thise?
Thanks,
Surveyor
Thanks,
Surveyor
