blowedupmotor87
So, I have decided to go with a Blazer tank for part of my fuel toting needs. I need the setup for an 86 (since that is what my crew cab is, and carbed) and want one that has baffles and is fully coated for corrosion resistance inside and out. I want the filler tubes, sender, straps, everything I'd need to swap one in. Where would be my best source? Thank you!!!!
With a tank below 1/4, I'd rather the fuel that gets to the sump, stays there.
