big carb,stock cam
chulisohombre
Bangor,Pa
i have a 350 with elelbrock intake 76 corvette heads with 2.02 intake valves.crane roller rockers with 1.6 lift.the question is:i have a holly 750 double pumper carb,will this be too much fuel for the setup i have without a cam?or will i get a little more horses and it should run better?thanx for any responses i get!!
Re: big carb,no cam
I went with about the same setup on my truck. Everybody around here said it would be fine with a 750 but it just poured too much fuel to the engine. I ended up going with a 600 and it runs perfect!
Re: big carb,no cam
What opens your valves if you don't have a cam in the motor? Or are you asking if that combo will work with the stock cam? /forums/images/icons/confused.gif /forums/images/icons/laugh.gif
