black junk on the wheels
adamforsythe
Maine
Hello,
Well I am polishing up my wheels because they are dirty. Well they have this black crap on them it's kinda like the rubber that you find on the road. Well I got 65% of it off, the wheels look good but I want them to look real nice. What do you guys use to clean up a wheel?
Thanks
ADam
yeah thats brake dust from your brake pads burning up.. just keep cleaning them with any strong house hold cleaner.
I use a variety of stuff, NeverDull, Eagle1 brake dust remover spray on stuff, Mothers Chrome wax. Typically I wash my rigs every two weeks so they never get very bad.
Dirty wheels
Castrol makes this purple stuff degreaser that takes that crap right off, but may not be too safe on really nice rims. Simple green works pretty good to and is safe on just about everything. I spray it on at the DIY high pressure car wash, and have at it, zip-zip, it is done.
The best brake dust remover that I've tried is Armor All Quicksilver. Spray, rinse, and wipe. The wheels look much better! None of the other wheel cleaners that I tried seemed to make much difference.
Since you live in Maine, I'm guessing that your wheels also see LOTS of road salt. That stuff turns aluminum into a black, crusty mess. I once cleaned up a set of wheels that were pretty corroded by using a kitchen/bar cleaning product called Cameo. It's made for cleaning aluminum. It will remove the corrosion (with the proper amount of elbow grease added ;) ) But it also dulls the shine of the aluminum so you have to follow up with a good aluminum polish to make them look good again.
the salt eats the coating off the aluminum so they will corrode
they are all corroded here, cant keep aluminums on a DD unless you just dont drive it during winter or polish them everyday maybe
the mags on my 81 c-10 are totally missing the coating form about 3" of the outer diameter of the wheels, totally eaten away gone and are dull black pitted but they are light and they actually fit the hubs tight like factory rims do,so im leaving them on there the tires are 31 x 10.50 RVT's though, too much for the little c-10 with its 2.73 gears its a dog, the poor old 350 doesnt get any rpm going at all,
you can buy brake dust shields for wheels.,
summit and etc,
good luck
