CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
Blaze the Monster Machine
1984 K5 Project for Dad and kids
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
Mine don't stop retracting, is like a Spanish inquisition torture device, if not that then being strapped to a table after angioplasty
centexk5
Premium Member
Georgetown, TX
Went to install a shift kit today. 4 pan flushes and filter changes and there’s still shit in the pan. Maybe because it’s missing all the check balls in the valve body? Who knows. It’s never slipped and it’s always shifted fine. Just hoping the shift kit limps it along long enough for me to afford the rebuild on the 4L80E and new Circle D converter.
346B09F4-B76A-4A9C-953A-136A6A621669.jpeg 09ABB2E6-2EC2-4EB5-9ACB-6C1FE37BB980.jpeg 01EF5D33-7EB8-4B21-AECC-CA6C5160AB11.jpeg 5227DB99-72C5-4028-93CC-13FA781CC1C2.jpeg
So while I source some check balls I decided to tear apart dad’s old Holley carb to see why it’s always been such a bad carb. We’ve always had trouble with it dumping crap loads of fuel into his engine no matter what. The thing has maybe a 1000 miles on it. Haven’t found much yet other than some trash in one of the bowls. The shop installed some 6.5 power valves so I’m swapping those for 7.5’s. Had to stop so I didn’t get to see what size jets are in it but I’m certain they are to large.
But the coolest update today is this.
folkenheath
Volcano Manifolds
Vendor
Wisconsin
Looks awesome!
Something to mention, it looks to me like your guideplates are not aligned quite right. I would adjust them so the roller tips are better aligned with the valve stems. If you loosen the rocker studs you can slightly move the guideplates to realign the valve stems, then retorque the rocker studs. Although maybe its an illusion and not necessary. Pictures only go so far.
centexk5
Premium Member
Georgetown, TX
After a rebuild on the Holley 4150 double pumper and a TCI shift kit in the trans, I finally got to drive it around and dang. This truck is actually fun to drive. Peppy and responsive. It’s not a manual valve body but I’m having so much fun shifting it I think I’m gonna order a ratchet shifter.
imiceman44
Hoarder extraordinaire
Premium Member
Lincoln, CA
Before you buy, let me get you a pic of mine.
If it's what you want I can save you money.
It never was driven.
Mike put it in my c10 and I want to put a regular stock column shifter.
centexk5
Premium Member
Georgetown, TX
Not much of a post but took it out for the first time since my last post. Idle is a bit low but it drives great. Need to play with the governor and shift modulator some. 1-2 shifts at 2000 and 2-3 shifts at 3500. Otherwise it runs and drives great.
Still waiting on the distributor and fuel pump for the 383. Mean time I’m just saving up for the 4L80e rebuild and circle d converter.
