I've had to use my fire extinguishers a couple times wheeling in the past. Friggin jeeps are always starting on fire...
I was wondering what everyone is using for battery hold downs. I have the stock type (small plate that bolts to the bottom of the tray on one side of the battery).
What about a small ratchet strap?
I was also looking at the bolt in or weld in battery box with a rail/bar that bolts across the top of the battery. I don't know if they will hold a regular (not Optima) type battery.
Will a ratched strap pass inspection for a battery hold down or will the stock hold down work?
Thanks for the input and can't wait to see everyone at BB!!![]()
Yea, someone's gotta define what tie-down means. Is the stock tie-down enough?
-Brian
http://www.jegs.com/i/JEGS-Performance-Products/555/10264/10002/-1?parentProductId=1338365
Mine is similar to this. They can be easily had for less than 20 bucks.
Don't mean to jump around in the topic hear but just a quick comment from past experiences on the fire extinguisher part. As I've been the victim of a couple trail fires myself and as well as others in my group. ATLEAST 1 in good working order Fire Extinguisher. 2 would be better, 3 is even better than that, get where I'm going. But even at 2, have one accessible for the driver/passenger and one that someone standing outside can get too. Also A HUGE imprtant thing that most over look, let those riding with you know where the extinguishers are in the rig. Most hardware stores sell fire extinguisher stickers for a couple bucks, get a couple and stick them near the mount. Then there's no doubt for anyone who has to access one in a hurry, as to where they are.
Sorry for the side track but I've come close to loosing my rig and had another friend loose a very nice buggy(even with extinguishers) I see it as YES a good extinguisher can be expensive but some of us have thousands if not 10's of thousands into our rigs what's another 200 bucks that might be needed to save us from loosing it all.
ok I'm off my soap box
The biggest problem with a battery running free is not the missle effect (unless it's inside with you) but the fact that it has 13-ish volts and ton of amps available and is surrounded by conductors to short it out. Bounce it out of the tray without even rolling over and you get a fire or explosion. We've done it before on a BB trip and it's not fun. Repeat, this happens without even rolling over, it can bounce out of the tray just driving and the best that can happen is the wiring gets jacked up and that's bad enough. A ratchet strap is way better than nothing, just make sure it's done.
... Bounce it out of the tray without even rolling over and you get a fire or explosion. We've done it before on a BB trip and it's not fun....
Wow didn't mean to start a crap storm but WALAH! had a uh-hem "friend" in a 4 letter word vehicle lose the battery right into the dizzy on a 4.0L. subsequently towed it out...long story.
We all hack our rigs to get trail performance, just remember the factory safety devices are there for a reason, and replacing them after you hack is a good idea
Would this pass the inspection?![]()
. I think I was there.
