CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
Blazer Bash 2022 not Last Minute Thrash
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Was likely the cause. That and lousy single shear...
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Yes, drivers side rear. No bump stop on that corner
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
I didn't make it, had life get in the way of finishing the LS swap on one of the trucks, but I'll be there for 2022!
Hey it’d be great to see you make it!
I’ve got another tire to mount myself if you want a good laugh!
Burt4x4
1 Ton First Gen
Premium Member
California (Modesto area)
Mee Too ~ If I wait for Greg72 it may be another 20years :zombie18: I'll be toast
So... only way to get to Moab is start the plan asap..
I put my 60 under the front in 06 and one upgrade I never did was chroMo + 35spl outer
Much more on the list as well....
Good to be here learking once again using all you'all's good ideas :saweet:
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Needs a sway bar
r3dd0g
Premium Member
Chandler, AZ
Maybe if I start now I can get a working tcase?
Got some plans this year...
Your plans should be:
- Fix what's broke
- Get some seat time
- Fix what breaks
- Go to Blazer Bash with a truck that's sorted out.
End of story, you never get to wheel because you always do major changes that you don't have time to test before you leave.
