Would really like to find a set of King 2.5 reservoir shocks. in the 8-10in shaft.Whatcha doin for shocks?
I seem to fall into that as well, I usually try and get all upgrades done and tested before 4th of July. Once the 4th hits I park the truck and go over everything then load it on the trailer and head to moab.My first time chiming in on this thread but I’m planning on making the trip so here goes.
Just finished up building the new transmission crossmember for the truck. The last one was too rigid. Split my tcase adapter into 3 pieces at BB2020, ORD hooked me up with a new one so I could get home, and I finally replaced it. Incorporated a quasi skid plate into it as well.
View attachment 404959 View attachment 404958 View attachment 404960
Next up is the turbo. Finally. Along with a new injection pump. Injectors. Glow plugs. Exhaust. Then a big brake upgrade. Fix some wiring maybe. Relocate batteries for the third time. Add a third battery maybe. Floor shifter on backorder. ORD Xtreme travel rear shackles and hangers.
All the good stuff.
Planning/hoping to have it all wrapped up by early summer.
We beat it out to BB2020 with less than 100 cumulative test miles on the truck, 0 off-road miles, and we’re pretty dang lucky to only have cracked the adapter, having driven over 2,000 miles from the Florida east coast, wheeled in Moab, driven as high as 12,000 feet in Colorado after leaving ORD’s shop, and driven 2,000 miles back to Florida.
I’ve always been a last minute thrash kind of person. Not by choice. Just seems to be the way it goes. But I’ve been steadily working to change that this time around.
Andy
it's back together now (except oil and the one cover bolt that stripped out at like 10 ft-lbs). It bothers me that the ring gear was loose on the carrier, but we'll have to see how it works out.
Some of the ring gear bolts had the faintest application of lock tight but I pulled them all, cleaned them, locktighted and torqued. I also pulled the bearing cap bolts cleaned, locktighted and retorqued those as well.
I picked up a 3/8" AR steel target I'm going to cut up somehow (plasma?) and weld on to the bottom overlapping the bottom of the diff cover to protect the bolt holes a bit better. I'm not sure what other people have done here or maybe they just replace the diff cover every time they take it off?
The plasma would only affect the heat treating in the immediate area, welding obviously would affect more.The AR plate may work. If its a target already its probably hardened. So plasma will work, it will of course affect the heat treat by completely junking the heat treating, but the welding will do the same, hence plasma is fine.
My skid is made from AR400. I've had issues with the welded plugs for mounting breaking the base material due the HAZ being completely unpredictable. When you weld it you are effectively bringing the material up to the austenitizing phase, then during cooling its forming to martenisite. But in a terrible way with a new alloy mixture of er70s6, and both base materials. I've read in some heavy equipment welding articles that's the main concern.
A cool approach, if possible, would be a bolt on AR plate that is then replaceable. But it depends on the ground clearance you want to sacrifice.
The rock jock front on the S-10 actually has a replaceable bolt on AR plate that's only about 1/8" thick. The main issue with it is the bolts get ground off.
I'm just not sure how I'd do something like that on the 14 bolt, plus I don't have a source for custom plates like that obviously.
