Blazer Door Glass Weather-strip Problem
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by DANL, Aug 28, 2002.
  1. DANL
    DANL Registered Member
    Mar 24, 2002
    18
    MEM TN
    Something isn't correct with the door glass to top weather-strip on my 72 K5 with double wall top. The weather-strip doesn't fit correctly and the windows, when rolled up, do not seal against the weather-strip. Weather-strip is new but appears to be to short. I just order new weather-strip, but is the same as currently installed.
    I need help and would appreciate any advice or photos.
    Thanks in advance.
    ...Dan
  2. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    I replaced mine last year on my 72 and got the drivers side like yours and mounted the pass. side correctly and it fits/seals now. It would appear that you mounted it incorrectly just like I did. Pull it out a bit...
  3. DANL
    Mar 24, 2002
    18
    MEM TN
    Thanks Spotter!
    ...Dan
