chevyuser74
ok im not big at all on body lifts but some of my mounts need replacing and i figure its cheaper than buying the stock mounts. what are your guys opinions on body lifts? and what am i going to run into in doing this?
I hate body lifts personally. the only way I would go at all is a 1 inch lift. It will give you some extra clearence in some areas. Things you are going to have to modify are your bumper brackets, lengthen your clutch rod, make sure none of your wiring is over stretched, possible steering column issues.
Why don't you just by a set of Prothane or Daystar urethane stock highth body mounts. $hit, you can get them for around $100.00 a set. Thats cheap for what you get.
A body lift is just blocks and longer bolt, You would still have to buy new mounts, I would go polyurethane.
With the poly mounts, you use the stock bolts that you take out, or you can just go buy some new grade 5 or 8 bolts from your local hardware store to save you the problem of trying to clean up the old rusty ones. Being in Wisconsin, I'm sure your bolts are rusty as $hit.
