Body lift
1HighK5
New York
Well I want to use a body lift to get some extra space around the truck and so I wont have to cut fenders. I've herd that HOCKEY PUCKS can be used to get the lift I'm lookn for. Will this work will hockey pucks crack or are they thick enough, and can I stack em to get me 3 inches. I know I can just buy a body lift kit but I have like Zero money and wouldn't mind do'n the extra work. Thanks
dont do it it would not be safe. wait til you have the money and get the body lift
2 bucks a hockey puck, you need 10 = 20 bucks
10in grade 8 bolts (not sure on the length) about 4bucks a piece, u need 10 so about 40 bucks
washers and nuts and locktite - 10
70 vs about 90
why do ppl keep saying hockeypucks will work. i hear that more and more and that idea just scares me.
alot of ppl are skeptical of body lifts to begin with and when you fab up your own from sporting good equiptment it just gets scarrier
Thanks I never really figured to cost of everything together I guess it's about the same and from the begining the hockey puck idea sounded cheep and I was not really into it just a thought I will just have to wait for the next payday and order it then
Hockey pucks for a body lift...Hmmmm? That reminds me...way back in the 70's when I raced motocross, and there was no federal mandate yet that all helmets be either DOT or SNELL approved, there was a saying about people that bought cheap helmets "$10 dollar helmets are for $10 dollar heads". :grin:
2 things 1: your life isnt worth it to skimp like that.
........... 2: that kind of stuff is what gives use good truck builders a bad name. so please dont do that.
To help clear this up a little I had seen this talked about before in previous threads and was just woundern about it I have never done a body lift before and I have seen people make em out of other stuff like solid blocks with holes drilled in them and peices of stainless steel tube with ends welded on them and other stuff and was just woundering if you could actually do it. But now that I've had plenty of answers I will go with my first choice of an actual body lift kit.
the best idea for home made that someone told me, even though this is already done with, was the 3" square steel pipe turned sideways.
