Body mounts + Body lift question
scottishdave
no-ton status :(
North Carolina
So i was putting together my LMC body lift and ORD 1" body lift and i got a little confused as to where the body lift pucks fit into the equation.
Here are 2 pictures of the way i have it now, each from a different location.
Looks like you have it right.
Basically they sit on top of the complete bodymount assembly....
I suppose the square shim could go on the very top for aesthetics reasons, but otherwise it's like you have it pictured.
:usaflag:
I think there were only shims on those 2 locations. The others did not have em. So shims on top huh.
Correct, they're just shims.
Putting them on top makes it easier to add or remove if needed, once you get to that point.
The progress looks great! :waytogo:
