Bolt size on the front tow hooks?
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
Anybody know what the bolt size is on the front tow hooks of a '89 K5?
Mine had that winch bumper on there that I traded a guy for a stock bumper and some other stuff. Only problem was the stock bumper came off a truck with no hooks so it's got short little bolts. I have some 1/2" Grade 8's sitting around but oy, they seem a bit loose in the holes in the hooks.:confused:
might be 9/16" then. Just take the tow hook with you into the hardware store when buying bolts.
Paint was drying this morning, they're hanging in the garage.
Anybody know off hand?
I just removed my factory tow hooks on my 89 blazer and they are 1/2" bolts. The holes in the frame are 5/8" holes though.
my early tow hooks came with 5/8" bolts.
I know the 73-80 are a totally different animal than the 81-up ... I'd betcha your first-gen stuff is like the 73-80.
Doesn't look so huge (that's a 31" x 10.5") but the round part is maybe 1" in diameter and the square part a bit bigger, so they're seriously fricken huge in comparison to the newer style.
-- A
I'm pretty sure when I took mine off they weren't real tight in the hole
You'd think they'd want it to be a tight fit to prevent shocks when you jerked on them...guess not.
I put my longer 1/2" Grade 8 bolts in with the hooks. Yes, definitely a smaller bolt than the hole. If I have some extra cash I might pick up some bigger bolts and replace the 1/2" bolts.
I just removed a set from a stock 91 K5 Blazer, bolts are 1/2-13 & they have a tight fit in the tow hook mounting holes
