5/8" X 11tpi grade 8 is what you need. Just figure out your length. Probably going to need something in the 4" to 4 1/2" range for length depending on your spring pack. Make sure to not go too long....it wont tighten up. Stick the dumb end of a digital caliper down in the hole to ck your hole depth. 1.5 times your bolt diameter will give you max holding power as far as a minimum depth for the bolt to screw in. So, for a 5/8" bolt, you would need to screw it in 15/16" deep to get the max the bolt will do without breaking.
