Bonehead move on my part...
Confedneck79K30
3/4 ton status
LA
so i put the hood on the abortion today, and shut it, well i forgot to assure the hood release cable was hooked up, and its not, how can i release that latch now?
With your cutting torch. :haha:
I think if you remove the grill you can get to it easily.
drill a hole in radiator support where lever is and stick a skrewdriver in there to move the tab.
My Hero !!! :bow: :bow: :bow: :haha:
seriously I'd try to drill a hole in rad support and try using a screwdriver or pick to release it. I'm on the road right now so I don't have access to mine to really be able to help much. Good luck
well,isn't THAT special!!:haha: :haha: thats why i put the 79 clip back on. and i would go with hood pins.
can you unbolt the latch assy.?
if the grille isn't in it you should be able to reach up with a screwdriver and release it.
