Its a toy, if it runs like h3ll he can get by with expencive gas for a while untill he gets heads. Hes not going to mess around with it right now, we are planning on break in sunday. Let me see what he has on the actual specs of the motor before stuff gets assumed.
Adam, it's not just that the engine may run poorly, to high of compression with the wrong gas can destroy the engine in short order depending on the magnitude.
I come up w/ static of 11.85 and dynamic of 9.08 on my Vette engine.
Heath, why does one model use Int closing plus 15 and the other not?
That's pretty high Dave, are you still running race fuel in that? (I know i could smell it at the build and greet) Have you considered switching it over to E85?
Which models are you referring too? I haven't looked at the others in quite a while, however, the one that recommends to add 15 deg to the intake closing is probably assuming you are going to use the number at .050" lift. So adding 15 deg will get it closer to the actual point where the valve is closed and it starts making compression. I think it's better to use the advertised closing number, which takes a little math if it only lists the closing points at .050". Yes, it's true that the advertised number will vary by manufacturer, I've seen that number listed at .004", .006", .015" lift, etc. However, simply adding 15 degrees is worse because cam profiles vary significantly depending on lifter style and cam applicaton.
Also, in reality its more complicated than that, because the air can start to compress at some lift number before zero lift depending on the piston speed and volume change relative to the pressure, valve size, etc.
With that said, this is just another way to guesstimate the limits of pump gas when you are selecting components, and is not an exact number anyway because of all the other variables such as ignition timing, combustion chamber shape, head material, sharp edges, temperature, RPM, etc. I believe the advertised duration number for intake closing is the most effective way to easily do that. It will get you to a much closer place in the piston stroke where you actually start compressing the gas, especially since you include the rod length in the calculation.
