marv_springer
Ok.... here's the scoop.
I'm building kind of an odd-ball doubler setup - but either way the front case is pretty conventional.
It's a 241 .... that I got in a box, disassebled.
The Doubler omits most of the hocus pocus inside the case.... but I still need the planetaries to work right.
Here's my question.... what is supposed to hold the planet carrier in place so that it doesn't slide back?
Right now, it shifts from hi to low... but if you aim the case w/ it's nose up, like going up a steep incline.... the planet carrier slips back toward the back of the case! I am missing something that holds it in it's fully engaged position.
I see there is a feature for a snap ring... or something where the sun gear is installed into the case. Something go in there that keeps the planet carrier in its place?
Any help would be appreciated from someone who has built a 241 range box!
Thanks!
Marv
Thanks!
Marv
