building the top end
adamforsythe
Maine
Hello,
Well I am going to rebuild the whole top end on my 350 (photo below). The heads are stock with a little bigger then stock cam. With the truck breathing right you can hear a bit of a cam sound. But I want a little more cam sound. Plus I need to beat my best friends that is building a 302. Hear is what I am looking at
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 270/278, Lift .480/.498, Chevy, Small Block, Kit
http://store.summitracing.com/default.asp?target=partdetail.asp&part=CCA-SK122433&FROM=MG
I did not want a HOLLEY part on this engine but Edelbrock does not make a Dual feed 750CFM CARB
Carburetor, Model 4160, 750 cfm, Square Bore, 4-Barrel, Vacuum, Dual Inlet, Silver, each
http://store.summitracing.com/default.asp?target=partdetail.asp&part=HLY-0-80508S&FROM=MG
Cylinder Head, S/R Torquer, Cast Iron, Assembled, 67cc Chamber, 170cc Intake Runner, Chevy, 302/327/350/400
http://store.summitracing.com/default.asp?target=partdetail.asp&part=WRL-042660-1&FROM=MG
How much HP would I be creating and would this be a good set up for a truck that will not see rocks or much low RPM driving?
Thanks
Adam
One more thing with that set up would I loose or gain HP if I went with a Dual carb tunnel ram intake manifold? How big would the carbs have to be? 375CFM each?
a tunnel ram of any sort would be a horrible mismatch with a mild 350 like that
