bummed, LED taillight not working correctly
digity
Brentwood Ca
Anyone running these from LMC. Heres what I got going on. 4 of the lights are bright while the others are lightly lit. Which to me seems correct assuming those will come brighter as the original 4 when the brake is applied. However, that is not happening. Wiring seems pretty straight foward. I also tried the other led fixture with the same results. Any ideas out there? :doah:
I have the dakota digital version. Do yours just plug straight into the stock plug? Sounds like you may have a grounding problem on the bed/tailight harness. If its a pickup, try running a groundstrap from the bed to the frame and clean up the grounds on the wiring harness to bed. You may have always had the problem but it just takes less voltage to light off the LED vs the 1157's.
