cadi caliper pics needed
Wicked Wolf Auto
T-ville, ut.
I just installed my 14 bolt with rear discs using cadi calipers and need to see how the stock e brake cables hook up to it, please post pics.
Thanks
They don't - you need a bracket.
Mine's home-made and works reasonably well.
If you can, get the bracket/lever/spring setup from a Seville - check with 4x4High for details.
Here are my caddy calipers using Seville/Fleetwood levers and brackets for the springs and then my own brackets to mount the cable housing in the appropriate position so the brakes actually work. The cables are the factory ones for my 89 blazer.
Are those custom brake hoses to your caliper from the hard line, or are they readily available from the parts counter? p#?
I've used lines for a '79 Chevette front brake.
Well i just searched car-parts.com and the closest one to me is 147 miles away:mad: I guess I'll have to try my luck at the pick n pulls and hope for the best
