AJM Blazer,
I got those numbers from a link on post # 21 of this thread.
Here's the link:
http://www.geocities.com/MotorCity/P.../Engineid.html
Let's see; from the Hot Rod article: Headers, 12.5:1 Compression (that means new pistons), new valve springs, hotter cam, Edelbrock Intake, milled heads. That's a pretty serious list of modifications (and $$$). Personally, I don't want an engine with 12.5:1 compression. I want to be able to run good old 87 octane gas.
How does Hot Rod Magazine come up with their horsepower and torque numbers? (I honestly don't know.)
Obviously on a dyno, but do they have an AC compressor hooked up as well as an alternator, PS pump, and smog pump? What about exhaust? Open headers or through exhaust pipes, catalytic converter(s), mufflers and tail pipes. What about air intake? Are they using a velocity stack or are they using an air cleaner with an air filter?
The factories changed their way of rating horsepower for the 1972 model year. They changed to SAE net HP (rated at the flywheel) with all accessories, normal air intake and normal exhaust system.
In 1971 (before the change to SAE net) Cadillac rated their 500 cid engine at 365 hp @ 4,400 rpm and 535 ft lbs of torque at 2,800 rpm. Before the change they weren't required to have all the accessories attached and operating, they could run whatever exhaust and air intake they wanted.
Gentlemen:
I'm assuming that all of you are at least somewhat like me; there's a limit to what you can spend, and you want your hard earned dollars to go as far as they can; especially after the government gets their very sizable take.
Are the Caddy engine's good motors? Absolutely. For me the cost, and hassle factor, aren't worth it.
You want a manual tranny behind your Caddy? Unlucky! You have to have the crankshaft machined to accept a pilot bushing. Cheap? I don't think so! You have to remove the crankshaft from the block to have this done.
You want something different: Go for it!
