thebluemax
I am in the process of doing the 3/4 ton conversion to my front ten bolt.
The backing plates and calipers have rust on them. It appears to just be surface rust on both.
I will be grinding the calipers to fit 15 inch wheels , so I will be getting most of the rust off on them. But the backing plates , I was thinking about putting a wire wheel on my angle grinder or just using a wire brush to get the rust of them?
Next question is....do I get brake specific paint for the calipers and plates? Primer, etc?
, and the cheap ones (which are all I buy
) are good for flinging wires at the speed of light. It's like having your own railgun, except you don't know where the projectiles will go ... they seem to be heat-seeking, inasmuch they end up impaling my feet or my stomach.
