vandelay industries
First let me apologize (for NOT adopting current technology---because i'm cheap and have chosen to continue to live in the past) and to ask help from 21st century inhabitants:
i can't get the idle down to normal in drive since i reactivated the choke. (new quadrajet)
1) i had wired the choke AND fast-idle cam completely open last summer, because i needed the truck running asap and didn't have time to mess with this back then. And it ran great with idle in neutral around 800-900 and in gear 500-600rpm.
2) After reactivating the choke (because it got cold) i can't get the curb idle down to normal---which is 500-600 rpm in drive. Now it's 700-800rpm in gear which isn't bad but it's not optimal.
a) The choke IS opening normally.
b) Hi step, hi mid step are definitely functioning normally. Not sure about low mid step, although the fast idle cam DOES appear to be moving to it's last position each time the choke opens fully.
c) i have the curb idle screw all the way out to the point that the throttle arm is barely touching it, if at all.
d) i did turn the fast idle screw out quite a bit to some improvement, but this shouldn't affect curb idle which makes me think something isn't right here......
Before i backed out the fast idle screw, curb idle was about 900 rpm in gear.
Just curious for your general thoughts on this and what i might be looking for? i have not ruled out the possibility of a vacuum leak, but do not feel strongly about it because what are the chances i could have gained a vacuum leak EXACTLY when i reactivated the choke?
i have also not ruled out the possibility of either a sticky vacuum advance or centrifugal advance, but again what are the chances this could have happened at EXACTLY the same time i reactivated the choke?
