q-jets are definetly the best carb out there... but they have nothing on fuel injection. If your gonna be hot rodding your motor over 420hp then the carb will be a lot cheaper but otherwise tbi will work. You'll need a BB tbi or holley 670 cfm tbi and a 2" bore intake manifold (could also use a carb manifold with an adapter) for anything over 300 hp. You'll also need to burn a custom fuel map. It's fairly simple but will cost you a decent amount of money.
However, if your close to stock hp you could get everything you needed from a junkyard for under 300 bucks (tbi). While your there you might as well pick up a BB tbi instead of the SB unit. Everything else (comp, harness, etc) should work fine with the BB tbi.
