Well, no link, but I am driving one. Don't know how much my experiences will help though.
It was a 2 door 3/4 ton, not a 4 door. It was done quite a while ago, so I do not remember what it cost,........Oh yeah, and its a Ford........
But for what it worth....
I ordered it new in '89. It came in on one of those car carriers to the dealership. There was an outfit across town that did custom truck bodies and installs of lift gates and that kind of stuff.
Drove it over there, they pulled the bed off, put it in a frame machine, and sawed the frame.
Before you cut yours, it would help to have a swb sitting next to see where the extra length is.
If I remember right, they measured either the spring hangers, or bed mounting holes between swb and lwb, and cut to make them match.
The beveled and welded the ends of the frame, and put a piece of plate inside and welded it.
The exhaust system had a spacer in it that slipped out and the two ends fit back together.
The truck has two gas tanks, so the side tank got swapped out for a swb one.
The rear drive shaft got shortened, because Ford did not make a swb drive shaft with the right ends.
I think the brake line had a section that came out. Don't remember about the E-brake cables. They may have swapped out with a set of swb ones, or just tied up the slack.
The new bed, gotten out of a junkyard off a truck that got wrecked with just a few miles, fit perfectly and all the holes lined up.
Back to the dealership for a quick paint job on the bed, and the truck looked stock.
Of course, then I took delivery of it, and really started to modify it.......
Its been 22 years now, over 300K darn hard miles, and so far so good........
